Deletes a direct route of a VLAN or set of VLANs previously leaked to the leak-to-VR.
direct-inter-vr | Specifies to delete previously leaked direct routes of specified VLAN(s) to a different VR. Adjacent hosts are also reachable in the specified VR. |
ipv4 | Specifies the IPv4 address family. Only IPv4 is supported. |
vlan | Specifies the VLAN name or list of VLAN IDs whose direct routes are leaked to a different VR. |
from_vlan_name | Specifies to use the specified leak-to-VR and replicate the direct routes of the hardware and software forwarding tables and the adjacent hosts of the VLAN name. |
from_vlan_list | Specifies to use the specified leak-to-VR and replicate the direct routes of the hardware and software forwarding tables and the adjacent hosts of the VLAN list. Range is 1-4094. |
vr | Specifies the virtual router to which direct routes are leaked. |
to_vr_name | Specifies the virtual router to which direct routes are leaked. If not specified, the context of the current VR is used. |
This command is used to delete previously configured leaking of direct routes from one VR to another.
The following example removes configuration for the direct routes of VLAN 'yellow' so those are no longer leaked to the leak-to-VR 'VR2'.
# configure iproute delete direct-inter-vr yellow vr VR2
This command was first available in ExtremeXOS 32.4.
